It`s a THING!!!
    Rubber tracks (and roadwheel tyres) don’t generally melt when the vehicle catches fire. If the rubber gets hot enough, it will start to burn and leave behind pale grey to white ash. Since the suspension of the M50 involves rubber springs, though, those would burn away and the vehicle drops to the ground, as far as the suspension arms will let it anyway. The tracks would probably retain some of their rubber parts, away from the actual vehicle fire, and you’d have steel cables (possibly snapped because of the heat) visible instead where the rubber did burn away.
    Another consideration, not about the tracks, is that Ontos crews tended to stash spare ammo inside the vehicle, because it had very limited ammo stowage. Many apparently even removed the commander’s seat and had him sit on a pile of ammo instead I mention this because the main cause of fires in AFVs is the propellant of spare ammunition, when that gets spilled and set off by hits that penetrate the armour.
    • The Smythe Meister
      • Jan 2019
      • 6248
      #62
      Just found this Andy, very interesting.
      the shape reminds me of the T60 Katyusha . Just about the same devastation when used.
      Love the idea of it being knock out , the blast damage to the rear is great.
      Love to Rach and the beast .
      Cheers John,
      Yeah,i agree that the Katyusha would have been as frightening,(But somehow,when i see the "Stalin`s Organs firing off in their salvos :flushed: ,and similarly the German "Nebelwerfer" ),they both seem a much more chilling machine to me!:rolling:
      Andy
        • Jan 2019
        • 6248
        #63
        Very nice work Mr. Smiff!!! Looks very devastated indeed and a great credit to your destructive skills Andy. Or were you scared to try and get all the barrels to line up straight and correctly..............Inquiring minds want to know...........
        Allen (Ret.)
        Thank you kindly mate:thumb2:,
        Well,i did intend to build this up as a knackered bit of machinery..... and having heard the comments about trying them full on,i`m very pleased i did!!
        Andy
          • Jan 2019
          • 6248
          #64
          Looking suitably bent out of shape Andy. Nice job.
          Thank you very much Tim:thumb2:,
          "Bent out of shape"..... the same name of a "Rainbow" album i had back in the day...... although one that`s probably best forgotten!!oop:
          Andy
            • Jan 2019
            • 6248
            #65
            Originally posted by minitnkr
            Well wrought.
            Cheers Paul!
            "Wrought" indeed mate...... hopefully to look even worse soon!!
            Andy
              • Jan 2019
              • 6248
              #66
              Originally posted by adt70hk
              Andy, a very nice start.
              Well done.
              Nice one Andrew,Thank you:smiling:,
              Andy
                • Jan 2019
                • 6248
                #67
                Originally posted by Jim R
                Hi Andy
                Nice looking damage. Realistic damage is hard to get right but you're certainly on the right track.
                jim
                Wow,Thanks for that Jim:smiling4:,
                It certainly is tricky,and i`ve a long way to go yet..... here`s hoping i don`t stuff it up!!:anguished:
                Andy
                  • Jan 2019
                  • 6248
                  #68
                  Andy,
                  Looking suitably f*%$ed up. Nicely done.
                  HA!! Cheers Scottie,(Dawg!!)....
                  .... I like to think i can f*%k most kits!!:tears-of-joy::tears-of-joy:
                  Andy
                    • Jan 2019
                    • 6248
                    #69
                    Mmmm, I still think that's repairable --- a weld here, patch there, another weld and perhaps - another kit! Looking good mate! Well done.
                    Steve :face-with-head-bandage:
                    :tears-of-joy::tears-of-joy::tears-of-joy:.... Nice one Steve:thumb2:
                    I`m sure "We can fix it"..... but why bother?!!!
                    I see your wounded emoji there.... are you OK mate?!!
                    Andy
                      • Jan 2019
                      • 6248
                      #70
                      Andy,
                      the Ontos had a form of suspension, which involved a lot of rubber, the tracks were similar to the WWII half track, in that they were steel reinforced rubber - any damage which involved heat or fire would cause them to disintegrate or melt. Now how you would model that- I have no idea!!!!!!!
                      ps. I have read that it was difficult for modelmakers to get proper dimensions off museum examples, because the suspension had decayed & collapsed - also the impossiblity of getting rubber tracks means that running survivors are non-existent
                      Thanks Dave,lots of good info there :thumb2:,
                      I have no idea re the wheel/tyre damage either,so as you`ll see...... i`ve made it up as i went along!....
                      I`m not a modeller who does EVERTHING to get things spot on..... but i do invest a bit of time checking things out,and get it as close as i can!
                      Andy
                        • Jan 2019
                        • 6248
                        #71
                        Another consideration, not about the tracks, is that Ontos crews tended to stash spare ammo inside the vehicle, because it had very limited ammo stowage. Many apparently even removed the commander’s seat and had him sit on a pile of ammo instead :smiling3: I mention this because the main cause of fires in AFVs is the propellant of spare ammunition, when that gets spilled and set off by hits that penetrate the armour.
                        JAKKO!! As ever mate.... THANK YOU for your info:thumb2:,
                        There`s an awful lot of interesting,and essential,points that you`ve aired!
                        Some i had thought of.and others not,(I.E. i decided to not make up fully loaded ammo racks).... all the rest i have tried to address,but this is my take on a burnt out wreck of this era.... see what you you make of my my meagre offerings!!
                        Andy
                        • Airborne01
                          • Mar 2021
                          • 4035
                          • Steve
                          • Essex
                          #72
                          Andy
                          Yup, fine mate - thanks for asking! Appreciate your concern -but in the words of the Jakkobites -Alles Klaar! (Sorry Jakko!) All is good, I was trying a little West Ham 'Irony'!
                            • Jan 2019
                            • 6248
                            #73
                            Evening guys,
                            This`ll be just a quick update as the evening meal,(Well,that sounds posh.... so i should`ve just said Tea!!),
                            I`ve started the external damage :thumb2: ....
                            So there it is for now!.... The pics are a bit garish,but once this AFV is complete,it`ll be just adding finishing touches to the Figures,and Diorama features!
                            But for now,i hope you`re enjoying the progress!!
                            Andy
                              • 18944
                              Andy
                              Any band that uses the line “don’t know about your brain, but you look alright” is probably best forgotten Andy…..
                                • 18944
                                Looking good, by the way….
